How to play qvod at chrome?
Hi guys,
I need to know if the qvod all in one media player is possible to run or compatible with the Google Chrome internet browser.
And also include all the compatible versions of internet browser.
Expecting some help,
Thank you.
Answered By 0 points N/A #175621
Hi Kimberly,
First of all download QVOD player version 5.4.111 from any website its free read carefully the steps how to play after installation open tom365 com translation also available of this Chinese site search what you want to see then click on that movie you want to play new tab will open you will see numbers under the QVOD logo.
Use the first link if there is more than one parts of your movie click all of them these links take you to another tab when these tab will open then open your QVOD player check tab of network tasks by opening playlist right side of your player.
Then you see some numbers or movie titles on a network task check percentage which is next to title when it reaches to .01% then you have to close your browser usually files are in RMVB or RM format or strange formats only opened in your QVOD its simple and easy way the version I told you in the beginning is the best one it can play more than 110 file formats.
