Ava larry
10 points
Posted on - 11/19/2012
Hello fellows,
How to play starcraft tv vlc? I would like to play games using television but don’t know how, is there a possibility of connecting my computer to my flat screen tv? Show me some illustration that proves the possibility. I know you can share with me your brilliant ideas.
Regards, Ava Larry.
How to play starcraft tv VLC?
Hi there,
To connect your computer to your monitor, your monitor must have a VGA or the Visual Graphics Array port and or you must also have a VGA connector cable.
But most of the latest monitors have a USB port and the HDMI or the High-Definition Multimedia Interface port.
If your computer has an HDMI port and you also have an HDMI connector cable then you can connect your computer or laptop to your monitor.
