How to play swf firefox?
Hello everybody,
How to play swf Firefox?
I got 16 files of .swf format rendered from swish max application.
What are those possible way to run a .swf file and give me some instruction on the set up?
I need some answer and solution.
Thanks and have a nice day.
Answered By 0 points N/A #184413
if you have .swf file you need a adobe flash or flash player.that you can download in https://get.adobe.com/shockwave/
or if you have Adobe FLASH software. the plugins of this software will make your .swf files run.
if you have a video converter. you can convert this to a universal player like .vid or .mp4.
Answered By 10 points N/A #184414
Hello Kristin Runaldou
Hope you are fine. There are some solutions to play .swf files on Firefox.
At first, check out the Firefox version. If it is below the version number 14 then update your browser first. In 14+ version go to Tools > Options > Applications.
See “Reset Download Actions”. If reset download actions work then you are ok to play. swf files on Firefox.
Finally install latest Flash player.
Hope this will help you.
With thanks
Greaney Mary
