Hi techyv,
How to play swf on galaxy ace? I love my Samsung galaxy ace mobile phone and on the process of downloading games and other important applications. I would like to know the process of playing some swf files using this android mobile phone.
Hoping for your help. Thanks.
How to play swf on Galaxy ace?
Hi Kristin,
You can play swf files on your galaxy ace using the swf player available for download on Google play store through the following link,
it allows you to play any swf file with support for zoom in/out. It has a high compatibility for most swf files, although the UI can be a bit unresponsive at some moments but all in all it gives a very reasonable performance.
For viewable swf files, you can convert them from swf to avi file types for best performance on your device. You can use an Swf to Avi converter such as "Moyea Swf to Avi converter pro".
Also if you are looking for an online flash player, you can try the Flash Player 10.2 by xda developers. It provides support for most armv6 and armv7 devices. And has received a lot of positive response from users. You can find it here,
https://forum.xda-developers.com/showthread.php?t=1155538
To run it on your Galaxy Ace,
1) Download the Flash Player 10.2
2) You will need to enable "unknown sources" in your Settings >>> Applications.
3) Open the apk file from where you stored it with any file manager like "Astro" etc.
4) Install the file.
5) Reboot your phone.
(Flash player 10.2 is compatible with browser support as well, but it does not run on Opera Mini. You can use an alternative browser such as Dolphin Browser HD).
Hope this helps.
