How to play swf window Media Player codec
 I am using windows media player 11. I have a number of swf files. How can I make it play in windows media player. Is there any codec that can make windows media player play these swf files?
SWF (Shockwave Flash) is a partly unlock depository for multimedia and particularly for vector graphics, created with FutureWave SOftware and has appear underneath the power of Adobe. SWF file format presently purposes as the main format for showing vector graphics as "animated" on the Net.
Before you can play a number of SWF files on Windows Media Player you must first convert SWF file to AVI file format. You can use RER Video Converter it is a certified tool for SWF file format conversion software, or RER DVD Ripper, easy to use tool to SWF extension file converter.
Best regards,
Heather marie
