How possible to create or perform html gallery add.
How possible to create or perform html gallery add. I would like to add or create a gallery for my website using html programming language connected to php. Share with me your brilliant ideas that can possibly solve this confusion. Also add some important information.
Allison Davy.
Answered By 0 points N/A #182065
In Creating HTML gallery You Must Now How The Codes Work. and make manual coding.and if you want you can use JOOMLA and put module that use gallery. if you want to learn this tutorial you can go to https://www.w3schools.com/ for HTML tutorial. And For JOOMLA Its https://www.joomla.org/. And If You Know Adobe Flash You Can Make A slideshow That Converted To HTML.
