How to possibly cut video avi?
Hello techyv,
I did some dubbing with my group mates for a multimedia presentation project, the dubbing session was done and all we have to do is to cut those video avi files in to pieces and edit some mistakes for finale.
We are having a problem on what software that could probably allow the user to cut avi videos.
Can you help me?
Expecting some help from you guys.
Thank you.
Best Answer by BrownAnna
Answered By 5 points N/A #183697
Hi Christine,
Why don’t you try Windows Movie Maker. It’s easy to use. Windows Movie Maker enables you to edit videos, add sound and pictures, and also add effects.
It’s possible that Movie maker is already installed on your computer.
In windows 7 press the window button then type movie maker. If not, you can download it free.
Try this link:
windows.microsoft.com/en-US/windows7/products/features/movie-maker
Hope this will help.
Answered By 5 points N/A #183698
Hello Christine,
To cut your video file which has .avi extension, i would suggest you to try Any Video Converter.
It supports almost all the formats. It not only cuts the file, but it will also convert your file into any desirable format you want.
It's free to download and very easy to use. To cut your video file.
Please follow the instructions mentioned below:
1. Download and install Any Video Converter from this link:
2. Open Any Video Converter and click on Add video Files.
3. When the file is loaded you will see some details on your right pane. Enter the starting and ending time of your clip you need to cut from the file.
4. Set output as .avi and click on Convert Now button
5. Your video file will be saved in your output folder.
This will do the job for you.
