Hi to everyone,
How to possibly perform a LG smart sync? I just got my new LG mobile phone and I want to sync all my smart SIM contacts as well as the email addresses and Facebook accounts. How will I going to sync all the data? A step by step solution will do.
Thank you.
How to possibly perform a lg smart sync?
Ok Here goes the steps:
1. From the home screen press the Menu key.
2. Then go Settings — Accounts and Sync.
3. Touch add account.
4. Touch Facebook Or Twitter whichever one you want.
5. Enter your Email Id And password.
6. If you want to import all your Facebook Or Twitter contacts then touch on Select Friends.
And That should do it for you.
Hi there Janet,
Depending on your phone model and mobile OS I could help you with your problem regarding syncing mobile contacts to their appropriate facebook/twitter accounts. One of the tool that can be used can be downloaded from Google Play, for LG android phones. The name of the app is Contact Sync. This is free to use and will sync your contacts in seconds. Hope this helps.
Waall Mike
