ramgen
Posted on - 11/14/2011
Does anyone know any link on how to pre-install zip files, because every time I run Qbasic, it always says that Full screen is not supported?
I knew about Dosbox. However, I don’t know the admin password and just using user control of the computer.
Can anyone help me with this problem?
Trevor
How to pre-install zip files?
Instead of answering to pre-install zip file, I am concern with the real problem which your screen do not support full screen mode. Running command prompt in Microsoft Windows 7 and Microsoft Windows Vista operating system in full screen mode was reported that the system does not support. This happened because of the video adapter card driver.
Better way of solving this issue is to disable temporarily your video adapter card driver. Just press Window + Break the click the Device Manager then expand the Display adapters, right click on your Video Adapter Device then on the properties dialog box, click the Driver tab then click the Disable button.
