Goldie Bond
20 points
Posted on - 03/20/2013
Hi Techyv Friends,
I am using Opera 12.14 for Windows on my PC. Whenever I open an Opera browser it popups any survey, how to prevent surveys when I start Opera, Please do the needful for explaining me a bit about the Opera settings and pop up blocker as each time i have to manually close the unwanted pop ups.
Thanks,
Goldie Bond
How to prevent surveys when I start Opera
Hello Goldie,
These days pop up blockers are enabled in the system but it can be disabled by following few steps. At first open your browser click Preference from Tools option. Go to the general tab there are so many pop up options including Block unwanted pop ups. Then you just need to select the option then click ok and hopefully your problem will be solved.
Hi Goldie, good choice of using Opera one of the best browser in the world. To stop any popup coming follow these steps, open browser > click tools> click references> then click the drown-down arrow next to "Pop-ups" a list of options will appear> click the options that says "Block unwanted pop-ups"> click ok . Once you've done it you may now enjoy surfing the net without any nuisance. Hope I helped you best regards
