Dear Techyv Experts,
I am using MS Outlook 2010 and in Windows XP and would like to about how to print custom form Outlook 2010 as I am unable to get the printout as that of the custom form. Please do the needful for suggesting a better solution.
Thanks,
Clive Walker
How to print custom form Outlook 2010
Hi there Clive Walker,
This problem can occur because if both outlook XPrint ActiveX & XPrint Add-in installed. To solve this follow these steps and try printing
Try turning off XPring Add-in
Step 1 – Go to tools in outlook and click option
Step 2 – Click another tab
Step 3 – Click advanced option
Step 4 – Click Add-In Manager
Step 5 – Uncheck the XPrint Add-In and close it
Now you are done
Best of luck
Taylor B Campus
Thank you.
