How to print screen in SQL Server command?
Hi there,
I have a large amount of data. I need the output information as it happens on SQL Server 2005 and not when the process is done. I need help on how to print screen in SQL server command 2005 to print output immediately without having another execution plan.
Answered By 5 points N/A #167948
Hi Sammd,
It is really a problem when you are trying to take a screenshot of a huge collection of data that cannot fit on your monitor. You are required to do a lot of work such as creating a screen shot of the first part and then, creating a screen shot of the second part and use an image editing software just to combine these two images.
Now your problem will be solved with the use of this computer application:
Snagit the screenshot software – it allows you to take a screen shot of the applications that can’t fit the screen. You can also select for the image format when you would like to save your screenshot.
Here is the actual software’s interface:
Screen Shot Software
Download it now and try it.
Here is the download link: Snagit the screenshot software
I hope this solves your problem.
