How to print on vbulletin ABC navigator
I am using the Vbulletin ABC navigator. But I cannot take a print. Is there any updated version. Or is there any way to active the printing options? Please let me know.
Thank you.
Thank you.
Hello Jeffe,
 ABC navigator does print yet you can download it for free you can benefit for it. It does support print function, you can even select print preview then select a list to print. Only has not been updated for quite sometime. If ABC navigator is not helping you, go to ABC explorer where you can adjust command settings when you print to a pdf or printer. ABC explorer will permit the user to create, edit, print, convert format windows based text.
Steeley Ney
