How to Print XPS Files Using Linux
I have been searching on the web for some ways to print XPS files using Linux Operating System. Considering that there is no viewer on Linux that is capable of viewing XPS files, what are some other ways and alternatives to the printing?
Best Answer by Jemison Stacy
Answered By 0 points N/A #162833
Dear Pam Gouin,
One of the best XPS viewers for Linux is the SANAtech XPSViewer  1.0 which can be downloaded from the following web site for a short trial period, or if it catches your attention, you can purchase it.
The website URL is:
http://www.sana-tech.com/xps.html
Hope that was helpful.
With my best regards,
Don Muench
Answered By 0 points N/A #162834
Hi Pam,
There is not much you can do to print XPS files in Linux Operating System. XPS is a windows only format I believe. The best I can imagine is to convert the XPS files into PDF if you want to view and print them on your Linux System.
