How to proper System Restore on my system?
My System Restore stopped working. Whenever I try SR, I can see restore points, however when I run it, I only get this message: “Can’t be restored to earlier time.”
How do I solve this?
Your System Restore Points could be corrupt. Boot into Safe Mode and run System Restore Tool. To do this, restart your computer, tap F8 repeatedly. The Windows Advanced Options screen appears. You can restart if it the screen menu does not appear.
Now select Safe Mode and hit Enter.
TonyBaijos,
Thanks for showing me on how to safely system restore. I followed your steps and I correctly did to use System Restore.
I am really grateful to you and also to techyv.com.
Thank you
Hello dear,
It is very easy to answer your question. As we know, computers create restore points and save files onto the hard disk. When we apply system restore, then the computer copies the files to the original location again.
Now, in your case, it seems that you have deleted these restore files, so the computer just shows the restore points, but there are no files available to restore.
I hope this helps you understand.
