How to properly convert odp to doc files?
I'm trying to convert ODP file formats which are XML based into Word doc files. Problem is, when they are already converted, they don't look the same. How can I properly convert odp to doc files?
Hello
I think you mean odp to doc. I that so, then I have perfect application for you. You can download it from here:Â http://www.download82.com/download/linux/odt-to-doc-converter-software/
Besides converting, this application is useful for repairing damaged files and recovering files if you don't have OpenOffice installed on your computer. So with application you can also open odp file with no problems.
You can find download link as well more information on link above.
Regards.
