How to properly overclock a CPU?
I'm planning to overclock two CPUs. One is Intel Core 2 Duo clocked at 2.4 GHz to 3.0 GHz and the the is Pentium 4 clocked at 1.8 GHz to 2.26 GHz. How can I overclock the above mentioned CPUs without facing any problems? What are the grounds to be taken care of after overclocking?
Answered By 5 points N/A #191897
As you know overclocking is pushing the CPU to run at faster clock speed provided by the manufacturers. For Intel core 2 Duo you can overclock the CPU simply by raising the Front Side Bus(FSB). For Pentium 4 you can overclock it by raising the Front Side Bus (FSB) until either processor limit or thermal limits.
You also can try setting the FSB from 100 MHz/200 MHz to 133 MHz/ 266 MHz.
