How to protect fields in Sharepoint WSS
I am fresh to SharePoint, it's easy to store, sync and share important content. It's really a helping tool. I need to know about how to protect fields in Sharepoint WSS. Please do the needful for getting a tip on this or provide any online tutorial regarding this point. Thanks
Answered By 0 points N/A #189332
Hello Jones,
I also agree with you that SharePoint is easy to store, sync. Now protecting fields is easy too in SharePoint. The administrators can assign permission to Users and User Groups. You can prevent the unauthorized users to see or edit the columns. I’ll suggest you to use SharePoint Column/View Permission 4.2.114.5 project management software. Follow the link below:
http://www.fileguru.com/SharePoint-Column-View-Permission/info
Just download the trial version and use it. It’s easy to use.
Good Luck.
