How to protect a folder in galaxy ace?
Is there a way that I can protect or assign a password to a specific folder in my galaxy ace mobile phone?
There are some confidential files that I stored temporarily in the phone.
Guide me along the setting or the process.
Waiting for your support,
Thank you.
How to protect folder in galaxy ace?
Hi Madison,
There are lots of ways to protect folders on mobile devices.
The most popular way is to install software, browse the folder within the software, and mark hidden.
Some trial software gives you the functionality to use a password for the software itself.
Solutions
Visit getjar.com and select your device correctly and browse the software.
Visit mobile9.com using a PC.
Good luck.
There are always many files that you will need to protect from publicity.
Then to check them from public view you'll have to protect them with a password.
There is some software for Galaxy Ace that assures such protection.
Get some of such apps from the link:
Hope this helped you.
If you have an Android Smartphone and you want to password-protect or lock a folder, try downloading Folder Lock on Google Play store. The latest version at the moment is Folder Lock 2.3.5. It requires Android 4.0 and up to work. Before downloading or purchasing the app, please read some of the reviews from users to somehow learn the pros and cons of the app.
The app allows you to password-protect your personal files, documents, contacts, wallet cards, photos, videos, notes, and audio recordings in Android phone. These items are hidden when you lock them with Folder Lock. The app also features data recovery. It has a built-in data recovery feature that will allow you to retrieve deleted files and folders.
