Jai Zadok
60 points
Posted on - 09/22/2012
I have been trialing various SWF Encryptor just to test whether they can effectively decrypt encrypted swf files and if it is really working well. I tried several swf Crackers only to find out that one of the decrypted application has been stolen. Is there anything we can do to prevent this from happening next time?
How to protect my file after I decrypt encrypted swf?
Securing the swf from being stolen is almost unattainable. You may try to obfuscate the codes to stop the swf to be reversed. The installation of SwfShield software may secure your work up to some level. But it cannot assure full safeguard. Its multilayer encryption algorithm stops from being usual decompiling.
Hi Jai Zadok,
For protecting files after you decrypt you have to try several SWF Crackers only to find out whether one of the Decrypted Applications has been stolen.
I have tested it myself and its all working good. So, I will recommend it to you too.
For further info you can visit the link
I hope that this will fix your problem.
Thanks & Regards
Gillam Janetj
Thanks my friends for your knowledgeable information. Gillam Janetj, I want to pass to you special thanks because your provided link is very helpful. Visiting this link, I have learned many tips about SWF Crackers, such information was not familiar to me before. Also thanks for your suggestion, it helped me to solve my problem.
