How to publish webmaster directory forum with advertising options?
 I have an idea to publish webmaster directory forum with advertising options. Please tell me how to find relevant information and softwares. To do this do I need any programming language knowledge?
Answered By 0 points N/A #146210
Hello ,
1. To publish a forum , either you should code the whole forum according to your needs or you can go for ready made softwares .
2. There are several softwares available as open source as well as the paid ones.
3. You can use vBulletin , phpBB , myBB . These are the best scripts available for publishing a forum.
4. If you use any one of these , there is no need to do programming .
5. You need to have hosting and a database to use these softwares. Installing the software is easy . Just read the read me file when you download any of these softwares and you will be done with the installation.
6. After installing , you can customize your site using various themes available on the internet or create a custom template of your own.
7. You should make all the database connections required by your forum to the databases in your hosting account.
8. Hope this helps you.
Thank You.
