Hello experts,
I want to download the 100 floors wallpaper but the zip file is protected with a password. Do I need to purchase it? If so, how can I purchase this? I need a guide and links on where to buy this. Thanks.
Thank you.
How to purchase 100 Floors Wallpaper?
You don't need to purchase that. It is absolutely free to download. You downloaded the zip file right? Look for a .txt file or a read me file. Extract it and open it. Once opened, read the text and you will see the password. Once gathered, copy it then paste on the field requiring the password. Once unlocked, copy all the wallpaper and paste it to a new folder outside the zip file so that you won't have to re-enter the password everytime you open it.
This is what the read me txt file looks like:
Hi there,
There are thousands of wallpapers of all sorts (including floors) available on the internet, all for free. But that's not to say that there aren't proprietary one's too.
Normally the proprietary one's are certified original and usual(not always) have high quality detail-wise. If you type floor wallpapers in Google image search, you can bet that countless will turn up and who knows, the one that you downloaded might even be there.
First of all, from where did you downloaded the 100 Floors wallpapers in ZIP format? If it comes from some forums try to ask the owner for the password. But be very careful because sometimes protected files often comes with viruses. I tried searching for 100 Floors wallpapers from Google and I could not find anything related to it except for the walkthrough and game guides. For your question if you need to purchase it to unlock the ZIP file, the answer is did you find any links from the file that says you need to purchase it? If none, then maybe the file is not really for sale. However, if you want to unlock the ZIP file, you can use the ZIP Password Unlocker. This is a password recovery utility. There is a free trial available from the link below:
Try ZIP Password Unlocker
