How to purchase PCM 2010?
I want to play the game PCM 2010 but I need to purchase it to play the game completely. How can I purchase this game so I can get the product key to register the game. Thanks.
Hi Christina Turner,
Just simply go to their official website and then select your console and click on the Shop tab. Select Pro Cycling Manager 2010 Download the full Version and a new tab will open for purchasing the game. It will cost you $9.99.Select your Payment Method and log in with your payment method account. Just follow the next instruction and enter all your information correctly.
Thanks!
Hello Christina,
To find the PCM 2010 activation key, you will need to do the following:
Hope this helps.
Carl
