How to put the Adsense code in my blog
I received a message from Adsense that I application is already accepted. I already got an activated account in Adsense. Now, what I what is put my ads in my blog. I don't know how to do this. Can someone help me. I'm using blogger.
How to put the adsense code in my blog
Copy and paste the code exactly as it appears in your account, without making any changes or edits. Changing the code in any way can cause errors on your page (and is against the AdSense program policies).
Paste the ad code between the body tags of your HTML.
If you're using a WYSIWYG editor (such as Front Page or Dreamweaver) it's a good idea to paste the code into the Code or Source view. Pasting it into the layout view will often result in HTML tags being added to your code, and will result in errors.
If your page uses frames, make sure that the code is pasted into the frame that contains your page's main content. We use this content to target ads.
Be sure to save and upload your pages to your server when you're done. If you're not sure how to do this, we suggest contacting your web hosting company directly.
Google ads should appear on your pages immediately. Initially, you may see untargeted public service ads (known as PSAs) for which you won't receive earnings. It may take a few hours for our crawler to visit your page and determine its content in order to provide targeted ads.
You might also find helpful HTML hints in the AdSense Help Forum. AdSense publishers share their knowledge and experiences in this forum, where you can feel free to post your own questions and search or browse for answers about ad implementation.
alphae
15 points
Hi Maria,
To add adsense code to your blog, I believe there should be some code that you have to copy and embed in your blog.
Once you have the code, open your blogger template and go to the dashboard and on the dashboard click on layout. In the layout section where you can view the basic framework of your blog with all the widgets, click on Edit Html. Click 'Expand Widget Templates' and search for the code <data:post.body/>
Paste the adsense code either at the beginning of the code to make appear above it or paste it at the end to make the adsense advert be below it.
But make sure you paste the code between the following lines of code:
<b:if cond='data:blog.pageType == "item"'>
paste adsense code here
</b:if>
Hope this helps.
