How to put email subscriber icon?
I want to get visitors from different methods and I learned that readers can subscribe via email. Now, my plan is to get readers that use their email. I know for a fact that this can be done. The only problem is, i don't know how to install this email subscriber icon. Can someone help me?
Best Answer by adam amer
Answered By 20 points N/A #80556
You need to do some work to install this email subscriber icon or box in your blog. For this first prepare your blog for this purpose. Make space and create content for this. Now put install this email subscriber icon.
For this first create an account at Feed burner or Feed blitz website. There are many websites for mail but these two for the blog. Then burn your blog feed to your blog. You must have to do this for adding blog with email subscriber. Now click on your feed title and follow those instructions set. Instructions must be completed one after one. Then you are able to add email subscriber icon or box in your blog.
Answered By 0 points N/A #80557
it is very simple you just need to go straight to https://accounts.google.com/ServiceLogin?service=feedburner and then follow me
you need to register in Feedburner so go straight to your feed status dashboard after you click on your feed name then follow these image
and after you do what exactly in image click on activate and then you will receive your code that you need to put in your site and with Feedburner it's done for now .
Hope this Solution helps you
