How to put live tiles in powerpoint?
Hi everybody,
I am using Microsoft office 2007 in my desktop.
I have heard that software giant Microsoft has introduced live tiles and more animation effects in their office suite.
Therefore,i want to learn the technique of how to put live tiles in PowerPoint?
Any video tutorial regarding this subject will be highly appreciated.
Thanks in advance
Best Answer by Baker Mich
Answered By 5 points N/A #187220
Hi Trevor,
You can surely create live tiles and generic animation effects in Microsoft PowerPoint 2010.
This is one of the foremost new feature introduced in PowerPoint 2010 actually.
I believe the following is the best tutorial on how to create animation from scratch in PowerPoint.
This tutorial from Geetsh Bajaj who is also a Microsoft MVP (Most valued professional) has more tips and trick on PowerPoint to help you acquire more skills on the topic.
Hope this helps.
Thanks
Baker
Answered By 5 points N/A #187221
Unfortunately, there is no special animation(inbuilt) or any template to create live tiles in Power Point. But, you can use animation settings that are effective too. Firstly, you should select text that you need. Then go to the animations and click the ''Add Animation''.
The gallery is opened and you just select what you need.
So, using them you can achieve your target.
