How To Put Photos On A Cd In Simple Steps
Hi. I am not very familiar with the CDs and DVDs. I need to copy pictures in the CD but don’t know the procedure. How to put photos on a CD? Please reply ASAP. Thanks in advance.
Hi. To learn how to put photos on a CD, first, insert the CD-Rom into the drive. If there is no drive, then you will have to buy one and install it on the computer. Then, open the Windows Explorer and click on the folder which is to be added to the CD. The already existing data can be deleted by clicking on delete.
Then, browse the pictures which need to be added to the CD and add them to the folder. After the pictures have been selected, you need to write the files to the disc and as a result of this, the CD will be burned to add the pictures to it. The pictures can be used after all of them get transferred to the CD.
Hope we helped.
