Inserting box in my blog using Feed Burner
I want to put the small icon box used by feed burner in my blog it will help to increase my loyal readers and visitors. The problem is I don't know how to install it. Can someone tell me how to do it?
Hi friend,
There are many ways to put the small icon box. I recommend to use Photobucket for this job.
I am using this so I am giving instruction on this.
First prepare your image which will use to create small icon box. So decorate that image and convert it into small size.
Then upload your image. After that you can add effects, layer, boundary etc on that image.
Now resize it into 125*125 or 150*150. These are the standard size.
Now use Photobucket for upload this image. Open Photobucket and provide your image link into it.
Then upload and save the page.
If you want to do it other way then follow this link for help How to Make a Blog Button with a Grab Box: A Tutorial
