Any Hill
30 points
Posted on - 11/12/2012
Hi to everyone,
How to put some Samsung wave widgets htc? I just got my new Samsung wave mobile phone from a friend and was not able to get an idea on how to put some additional widget in my screen. I want a step by step solution to add those widgets properly, I will add some applications.
Thank you.
How to put some samsung wave widgets htc?
Hi Any!
You can get widgets for your phone at the Google Play Store or Android Market. You will need a Google Mail account to login. If you don't have an account yet, sign up for one. You can sign up at the Google Play Store website or Android Market. Use your phone's web browser to go to access the Google Play Store website or if you have an Android Market widget or application in your menu, press on it.
There are a lot of free and paid widgets to choose from. Once you have found something that you like, press on it and Install. The widget will automatically download and install itself in your phone.
