How to put themes on MSN official homepage?
Hi
I usually use MSN at my office. When I visit to the IT department I saw that on of the MSN homepage is different from the usual homepage. It is really beautiful and attractive. Is there any kind of way to install msn homepage themes?
Thanks
Answered By 0 points N/A #138860
Hi James,
It's very simple to customize your MSN home page just go to my.msn.com when you open this site a new window appears from where you can add four tabs e.g. interment, sports, money, news, lifestyle etc and also number of themes on this window
first of all on the same window click your account to sign in after then on top of right hand side there are two options customize and Add contents, windows open name customize tab in this window have to tabs themes and layout you can select your theme and its layout from this window and save on left hand side there is option add a tab also add tab which you required and save now see your customize home page.
