boby boby
30 points
Posted on - 02/26/2013
There are many computer technical support online. But the thing is that every technician is not an expert in every field. Even for a software there may be different technical part. So we have to go to the right place. So my question how can I determine it?
How to reach right computer technical support online?
i see your post and you're asking on how to determine the right site for a support may be my answer to that is, in every software that made/you buy there is always a site that indicated to it that will give technical support to you — you can see it that in there manuals, i think in that simple things you can go to the legitimate sites, thank you!!
Hello Boby,
One of the best online technical support i know is Microsoft forums. You can post your problems and the right person who will be specialist of that field will provide you the relevant answer that will fix the problem. Usually every software company has it's own technical team who are specialized in their fields. For example if you have any problem regarding Adobe product so contacting Adobe support team will resolve your issue. Similarly there are different companies who can do the task for you as well.
