What is a ddb file? I have them in my computer and I wonder if what are those files for? Can I view and open them? What program should I use? Please tell me How to read ddb files using my computer?
Thank you.
DDB stands for device-dependent Bitmap format like BMP, DIB. This file format is used by video card manufacturers who make graphic cards. DDB files are not designed to be opened manually, though they can be opened with a supporting third-party application.
DDB File also refers to DProfiler Cost Database. .DDB files are used to hold partial costing information for DProfiler databases.
Through image viewers like Photoshop or IrfanView, you can open .ddb files.
Hi dear,
DDB is a file format that uses for the device-depended bitmap or raster graphics. Usually those kinds of files are use of hardware manufacturers such as graphic card makers. They are not opening directly, but can open by third party application that helps to open like acdsee image editor.
You can open these files by using this image editor.
