How To Read XML File Us7ng Simple Methods
Hi. I am not very hands-on with XML and the other software. I want to learn how to view the files which are in XML. How to read XML file? Please reply ASAP. Thanks in advance.
Hi. To learn how to read XML file using a web browser, first open the browser be it Firefox, Safari or Chrome. Then, open the URL of the XML file in the browser’s window. After this, view the XML file using XML tags. To save the file, click on the file and then select the save option. Select the location where the file needs to be saved. According to the second method, the XML file can be viewed on Windows as well by downloading the XML notepad. After the download gets finished, install the notepad by following the instructions.
Open the notepad and on it, click on the file and then open. Browse the file from the PC and click on open. Then, view the file in tree view following which the output can be viewed in XSL output. The XML files can be edited in the notepad as well.
Hope we helped.
Notifications
