I've been expecting a few important emails these days and therefore I would like to be informed once it received to my Inbox as I am too busy I would like to receive it via SMS at least a notification is it possible to do? If yes somebody please help me to do it.
How to receive a Gmail Message Via SMS?
Hi Sean,
Yes, it is possible to receive email via SMS. But, first, you need to configure the settings of your Gmail account. Also, you need to enter and verify account code to authenticate your account. Please refer to the link below to see the step-by-step process.
Receive email on phone via SMS – This link will guide you through the support section of Google which discuss on how to properly configure the Google account to receive email via SMS.
Ware
Hi Sean A Harwood,
It is very simple and here how you can get it done. Please follow the following steps:
First of all, you need to create a Gmail account.
Once you have your login and password ready to use, log in to your Gmail account.
Select Account setting at the top of the screen.
Select SMS and phone settings.
Add your phone number to receive Gmail to that number.
It shall send a verification code to your mobile.
Enter that code on the Gmail screen.Once done, you can receive Gmail emails on your phone.
Now you are good to go.
To receive email via SMS, perhaps you should try these following steps:
1. Open your Gmail.
2. Click your photo at the upper right part, and then click ‘Account’.
3. Click ‘Edit Settings’ beside SMS Hangouts.
4. Add your phone number where you want to receive your mails.
5. Verify your number by entering the verification code that was sent to your number. Once your number was verified you can now receive and send from Gmail.
For more information you can check this page.
Martine Paul
