How to recognize the MS Cloud platform in Windows 7?
The 2005 version of the Microsoft database server does not seem to be recognizing the Microsoft cloud platform that I obtained and integrated to my Windows 7 system. When I uninstalled the database server, there was still no recognition. Are there ideal combinations for these programs for all of them to sync and work or are there just steps that I missed that need to take so that my cloud platform tools may be functional?
Answered By 15 points N/A #109324
Hello Gen-gen,
I suspect that the Microsoft database server version that you are using is not compatible with the Microsoft cloud platform that you are using hence the reason why it is not being recognized.
I will therefore advice that you try Microsoft azure which uses the SQL server databases to host the Microsoft cloud services that you are using. With Microsoft Azure, you will have the capability to host the databases on multiple servers and the services will be implemented with transparency, and the prices for hosting are reasonable, that is as low as $ 10 every month for 1 GB space.
Hope this helps.
__
Regards
Clair Charles
