How to record audio from youtube to cd
I want to record audio from youtube videos to cd. May be some sort of software will be helpful for this.
Please tell me how to do it.
There are various websites that provides service on converting YouTube videos to audio file or MP3.
Solution 1: You can try http://www.flvto.biz/ or http://2convert.net/youtube-downloader-for-windows/
You just have to copy the link address or URLÂ of the YouTube video that you want to convert and paste it in one of the websites mentioned above. As soon as it is done with the conversion, you may download it in your computer.
Solution 2: Another alternative is to download an add-on in your Firefox web browser.
You can try https://addons.mozilla.org/en-US/firefox/addon/youtube-to-mp3/
Similar to solution 1, you just have to paste the URL of the youtube video that you want to convert and download it.
After downloading it, you may now record it in a CD.
> go to My Documents -> Downloads
> copy the files that you want to put in the CD
> go to My Computer -> DVD / CD – RW Drive
> paste the files
> select write to disk
good luck!
You can download audio format file from any video on YouTube. You can use software called Audacity. It’s nice software. It will capture what you play on your computer. It will capture the audio file then you can save it to the desire location. Then, you will burn these files to a blank CD or DVD.
It’s easy as that. If you want to download Audacity, you can go to –
https://sourceforge.net/projects/audacity/.
Hope, it will help you.
