How to record Long Playing recording with Audacity?
I have Audacity 1.2.6 installed and it started throwing errors while trying to record Long Playing (LP) recording. I completed one side of the record without problem. On turning the other side and start recording the Audio track, I got message that appears for almost 10 times per second and I was unable to cancel it. The error states: "Cannot open file 'C:UsersadminAppDataLocalTempaudacity_1_2_tempb00590.aub00710.au' (Error3 : The System cannot find the specified path) Date,Time…" On searching the file using the Command option shows:
Verzeichnis von C:UsersadminAppDataLocalTempaudacity_1_2_temp
09.01.2011 20:34 <DIR> .
09.01.2011 20:34 <DIR> ..
09.01.2011 20:03 1.060.956 b00000.au
09.01.2011 20:03 1.060.956 b00001.au
09.01.2011 20:03 1.060.956 b00002.au
09.01.2011 20:34 1.060.956 b00589.au
09.01.2011 20:34 1.060.956 b00590.au
09.01.2011 20:34 1.060.956 b00591.au
592 Datei(en), 627.569.856 Bytes
2 Verzeichnis(se), 62.740.803.584 Bytes frei
On clicking the rewind button sets the Play option with no result on clicking it. And on pressing the forward button displays the following error and the value of b00717.au keeps on increasing with every forward clicks:
"Can't open file C:UsersadminAppDataLocalTempaudacity_1_2_tempb00590.aub00717.au"
Can anyone please explain the procedure for recording an LP and state where I am going wrong?
If possible, please help me locate a tutorial so that I can follow it.
