How to record output voice from speaking pets for computer?
I love the speaking pets for computer and have downloading many such applications like talking parrot, dog and bunny. What is the easiest way to record the output voice. I have windows XP installed on my system.
Answered By 0 points N/A #148275
Sound recording process allows you to record your own voice or any other sound directly to the computer. You can save them after recording. Windows users can have that advantage from their start menu. It’s an easy process. If you want to record your voice or any other sound to your computer, you can go through these simple steps-
1) Insert your microphone to the computer.
2) Go to your start menu.
3) On search bar type ‘Sound recorder’
4) Start recording your sound.
5) Stop when you want and then save where you want to save it. It will come with .wma file.
