How to record Skype call Windows?
Hi techyv,
How to record Skype call windows?
My current operating system is Windows 7 starter 32 bits with an Intel dual core computer.
I am having a hard time figuring out if there is some possibility to save and record my Skype calls with my family and friends.
Hoping for your help.
Best Answer by Clotildec barbara
Answered By 0 points N/A #173996
The best way to record Skype calls is using external plugging software. Essentially Skype does not provide any way to record your voice or video calls. But you can record it through using below soft wares.
1. You can use the Evaer Skype Video recorder to record your voice and video Skype calls.
Ever provides an excellent way to record your Skype calls and it record your data with high quality.
2. In addition you can use Supertintin Skype Recorder to record your Skype calls.
Supertintin Skype Recorder is lightweight super faster software for Skype Call recording.
Thank You
John Major.
Answered By 0 points N/A #173997
Hello Anny Hill,
There are many external plugins to record your Skype calls. I will list out the plugins which will be suited for your requirements you have provided.
Solution 1: Ifree Skype Recorder
1. It is free, no limits.
2. Automatic or Manual Recording Capabilities.
3. Built in mp3 player for relaxation.
4. Automatically chat reply when you leave the computer.
These are some of the features existing in this software which you get free.
Link: http://www.ifree-recorder.com/
Solution 2: You can also use the Evaer Skype Video recorder for recording your voice and video Skype calls.
1. Recording Skype Video and audio Calls.
2. Easy to use for Skype video and audio interviews, conferences, podcasts etc.
3. Automatic Chat reply.
You should Purchase by paying USD $19.95.
Link: http://www.evaer.com/
So I suggest the Solution 1 is the best for you.
Thank you,
Clotildec barbara
