How to record sound directly with Mac?
I want to record my daughter's song on my MacBook Pro Retina. What are the steps and tools needed on how to record sound directly with Mac?
In your Macbook, there is a changeable auditory port which works for sound in or sound out functions. The port with headphone sign can be used as a microphone port also. To do this, you have to change the preference option.
For full method to use the device of recording go to the cnet.com.
https://www.cnet.com/how-to/record-through-your-macbooks-headphone-jack/
Dear friend,
Follow this guide step by step
1- Open quick time player at first.
2- Then from file menu choose new audio recording.
3- Sound recording video will appear.
4- Then you choose the input to be your microphone and select sound quality.
5- Select the destination to save the record.
6- You can adjust the level of microphone from a button under recording button.
Notifications
