Hello friends,
How to recover a corrupt msg files ntfs storage? My business partner is having a problem with a corrupted file in his ntfs storage, he asked me to help him regarding the corrupted file so I came here in techyv to get some solution. We need some help or any recovery tool that might save those files.
Thanks and Regards,
Kristen James.
Hi there user:
Messages or files from way-way back time are important. Before I give you the solution, I would like to give you an advice to avoid this issue next time around, always back up your messages or files. Â
Recover these corrupted messages by using NTFS Undelete software for free. Here’s the link where you can download the software.  https://www.ntfsundelete.com/
Hope this could help. Thanks for posting your query here at techyv.com. Feel free to post again.
Best regards,Â
Hi Kristen,
              There are a lot of solution you can try to resolve this issue:
Run a chkdsk on the ntfs media, this will check the integrity of your HDD and repairs any corrupted sectors thus, saves the corrupted files.
Use TestDisk software, this can recover and repair the filesystem on your NTFS media. It will explore the disk and you can even set it to repair bad sectors manually.
