Hello experts,
How to recover corrupted bin files? A few weeks later I tried to open my computer desktop with Mac operating system and was surprised to see my files corrupted by some viruses or any malicious software that enters my computer registry. I was bothered and worried, can you please help me recover those bin files?
Hi Kimberly Walker,
IÂ searched a solution that may help you with your problem.
Firstly click Start, and Locate All Programs.
Then click Accessories and then right-click the Command Prompt.
Next run as Administrator and fill up the password.
Then at the Command prompt just type sfc /scannow then hit Enter.
Finally just wait for the Computer is scanning your files and it is also repairing all of your BIN Files.
Hope it helps.
Hi Kimberly Walker,
Download and install the VirtualLab Data Recovery, because this can recover data even if it’s corrupted or deleted. After installing click on the corrupted file and on the left-hand side you will see the description of the file.Â
Click on the repair option. After that click on the recover button and you’ll see a pop-up for choosing where you want to recover files to be restored to your system.
Hello Kimberly Walker,Â
You can recover corrupted bin files by the use of software called file recovery. I highly recommend this software due to the following:
• It can help you recover not only corrupted bins but it can also recover hard drive failure and also accidentally deleted files.
• It also scanned for recovery files even though you have already deleted it from recycle bin.
