How to recover data ?
Hi all, I' m using Nokia N73. I've lost a MP4 video from my memory card of 4 GB. But i want this video back. I've tried personal but i can't do this.
So i need some help for this issue.
Thanks a lot.
Thanks a lot.
Hi Jayson Mars,
Well, surely that is a big a problem recovering those deleted or lost important files from you memory card. Well, your phone is a Nokia N73 so I must assume your memory card must be a mini SD or a micro SD Card with a jack. Anyway, you can recover those files through recovery software. I suggest you use Zero Assumption Recovery. It is compatible with a lot of memory cards including your Micros SD Card, and Mini SD Card. Not only does it recover deleted files but also it is capable of restoring files from corrupt and damaged memory card. It is so easy to use.
Hope this works.
>>Mathew Joni<<
Notifications
