I have damaged 4 GB SD card that include really important information to me. So I need to recover this card. So I like to hear some suggestions regarding the damage SD card fix at least to get my data back.
Thank you.
How to Recover Data from a Damaged SD Card?
Hi Marcellatierra,
First, try inserting your SD card in another computer, or use another card reader. If this does not work, visit this website: cardrecovery.com.
CardRecovery – It is the most reliable software for recovering data on your SD card. It is fast and safe, since it only performs Read Only operations on your memory card.
Also, Recover My Files – This program will scan your SD card for 5-10 minutes, depending on the size of the data inside.Â
Thank you,
Adrian Leano
If your SD card is damaged physically then there is difficult to repair this. But if you card is not physically damaged then you need to format your card. if your using window operating system then you need to uncheck the option i.e quick format from the format disk dialogued box as shown in figure
Thank you
At first you have to sort out how kind of damage it is. If it is physically damaged then you have nothing to do to recover the data. If the damage is not physically happened then you can recover your data by formatting or resetting the card.Â
AS400
Easeus Data Recovery Wizard Free Edition, this software can recover deleted pictures, movies, folders, files and other documents even after the Recycle Bin is emptied, recover files due to system crash, format, virus attack and lost partition. It provides recovery of the data from hard disk, USB flash drive, Memory card, or SD card in different Windows version.
Best regards,
If your data is highly valuable, I recommend opting for licensed and paid data recovery software. Free software are abundant in the market, but for your needs, its appropriate to go for a proven provider
I give you some links, you can check them out
I think its working​. To fix a damaged or corrupt SD card on your phone, first, you need to determine the type of SD card you have. If your computer can't read the files on the SD card then you can use a recovery file or scan the card to remove corrupt files. You can also use tune up utility, Data recovery, Memory card backup, Recuva, such kind of software.
