How to recover data from my PC?help
Hi guys,
Please help me recover my data from my PC. Actually I saved some importanat files in my PC few days ago and due to some reasons I had to format my PC and now I'm unable to find my saved files. So please help me how to retrieve my files back from PC. Thanks in advance
Best Answer by
Answered By points N/A #186316
Deleting files from your PC doesn’t mean that the files are really deleted from your HDD. Only the icon and area of the file is deleted from OS’s information table. The file still exists on the drive and waits until another data has overwrote it.
There are many programs to perform this recovery task. I recommend MiniTool Power Data Recovery. It’s easy to use and powerful enough to recover your data from your HDD if they’re present and not overwritten by operating system.
If you’ve deleted files from a drive which is being used heavily, there’s a little chance of getting back the files. If it’s on a low using partition, it’s easy to recover. Also, the time when you deleted also matters.
Answered By 0 points N/A #186318
You have lost your data as you have formatted your computer, it`s been really easy to recover data there is a data recover software named as "Remo" software. With the help of this software you will be able to retrieve your formatted data easily. To download this software visit this link.
Answered By 0 points N/A #186321
There are many programs to perform this recovery task. Anyway, pay a visit this Techyv post to get more indea.
Can i retrieve my data?
