How To Recover Deleted Excel Files Using Some Simple Steps
Hi. I have recently started using MS-Excel. I am not very familiar with it, so I accidentally deleted a worksheet from it. How to recover deleted Excel files? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #121241
Hi. To learn how to recover deleted Excel files, first, open MS-Excel from the start menu. If the software was closed without saving the file then, it would appear in the document recovery pane if your file is present there. Then, open the recycle bin by double-clicking on it and if you find the worksheet there, then the file needs to be right-clicked on and then select restore the files.
Then, click on start and computer and select the folder where the worksheet had been saved last. Restore the file to its previous versions by right-clicking on the folder after which a list of folders which have been gathered from the backups will appear. However, if you do not use Windows backup or system restore has not been enabled, then you will get an empty list. If the file appears, click on the restore option so that it appears in its original location again.
Hope we helped.
