Hi techy,
I have an important record in digital recorder accidentally being deleted with my cousin. There are any applications to retrieve or to recover deleted file? A recorder applications? Please help me I really need to recover deleted file recorder app.
Thank you.
How to Recover deleted files recorder app
You can download Digital Voice Recorder Data Recovery Tool for windows (i.e. Stellar Phoenix Photo Recovery) OR Digital Voice Recorder File Recovery Software for Mac (i.e Stellar Mac Photo Recovery). After downloading the right software follow these easy and quick steps:-
1. Connect the digital recorder to your system.
2. Install the recovery software on your system and let it scan the digital recorder fully to look for recoverable data.
3. Preview and recover the files found.
Laz Zebbena
There are available applications that will do the same job but all of them are not trusty and working. Here goes the good ones.
Steps on How to Recover Deleted Files
If the deleted file is stored on your local hard drive, the success of the recovery is still not guaranteed. The success will depend on which drive the file is residing.
If the file is residing on the system drive, drive C, recovery is low because files are constantly getting created and deleted on the system drive and this can surely overwrite the sectors originally occupied by the deleted file. Download PC Tools Performance Toolkit and install it. Once installed, start PC Tools then go to “Recovery” tab and click “Recover Lost Files”.
On the next screen, set the scan type and select the drive to scan or just leave it as is to select all drives. Click “Start Scan” to begin scanning your drive. When the scan is complete, look for your file on the list and restore it.
Most of the time, the recovered file is no longer usable or already corrupted so better check the contents of the file to make sure it is the same file or the contents are not changed.
