How to recover a deleted partition not formatted ?
I have 2 partitions C and D, and I wanted to reinstall Windows XP. So I boot the Windows XP CD and there I wanted to re-allocate the hard drive and I removed D. Noticing this error, I immediately leave the facility. And now when I'm on Windows there are only the C partition, but the D is gone.
Note that I did not start the installation and I did not format D.
Best Answer by Sharath Reddy
Answered By 590495 points N/A #126702
There's a lot of partition recovery tool but try first PartitionMagic in recovering the partition that was accidentally deleted. But be sure that the partition to recover has not been touched or whatever after it was deleted. Even a single file copied to it will result in an unrecoverable state. Install PartitionMagic in another computer.
Remove the hard drive to recover from the CPU then transfer it to the computer that you have installed PartitionMagic. Run PartitionMagic there and try if it can still recover the deleted partition.
Search the internet for a site that still offers free download of PartitionMagic. It is no longer produced by PowerQuest.
Answered By 0 points N/A #126704
Dear, Firstly you need recovery software that you may find a lost partition. Try Active@ file recovery, or some of the many alternatives. Some programs are free but most are commercial.Pls try it to do
