I am a newbie in the computing world and I got scared when my flash drive got infected by viruses. The only way was to format the drive to avoid infecting my computer. So I lost all my high school graduation photos. Is there a way to recover them? What software should I use? Also provide the steps needed to recover all photos.
Thanks in advance.
How to Recover deleted Photos from flash drive
Hello, EaseUS data recovery software is the best for you to use,you can download a free trial which supports data recovery of upto 2GB volume for free before getting the full version. It also has a command to select the data types to recover,whether deleted, formatted or damaged. The recovery wizard is user friendly so don't be afraid, its easy to it yourself.
N.B Next time just don't format your flash,instead scan with the antivirus installed in your computer to avoid loosing your data.
Don't worry because you can easily recover your old files. But at first stop writing anymore data on your USB or your files will be more hard to recover. To recover your files you need a simple recovery toll named Recuva. The steps are given below:-
1. Download Recuva from here.
2. Install the program.
3. Choose the drive and select recover files.
4. After the process is complete you will get your files back.
There are several recovery software,s that can be downloaded online. They can help you retrieve lost photos and files.
To get more idea visit this Techyv page.Â
Retrieve photos from a damaged memory stick
Dont worry, just follow my instructions that are listed below.
To see your photos again on your flash drive that you have formatted or deleted, just download Softorbit Flash Drive Recovery software as shown in the image, install it to recover your formatted flash derive. Once you install this software select recover options. This will give you the solution to the problem.
