Hello fellows,
Yesterday I accidentally deleted my business partner’s message including all the attached important files. How to recover deleted sent Facebook message? I was so worried that I cannot get it back, so I decided to post here in techyv.com maybe you could help me fix this issue. Give me some tips to recover all the files I have deleted.
Your help will be much appreciated.
It is a very simple and easy process if you want to recover your Facebook deleted messages. Only you have to do is to sign in into your Facebook account and go to the messages section and then select more and from more choose to show you the archived messages. It is very simple.
Hi Gary
Unfortunately all deleted Facebook messages cannot be retrieve. But you there is one way to restore the messages you deleted.
In your browser go to history or (ctrl+shift+H+) then a pop up will open, now restore the history from the time you receive the message, you should be able read and copy the message your business partner sent to you.
You can actually try to contact Facebook and ask them to restore your message as they have everything stored in their database. Don't know how to write to Facebook regarding your issue?
Well its a pretty simple process :
1. Go to settings on the upper left corner of your Facebook interface.Â
 2. Then community forums.
3. Enter the required keywords for your problem and look for any such open forums if not found click on ask questions  to manually post the question. Â
Or you can check the archive option from your message to retrieve your lost message.Â
